跳转到主内容
Canon PIXMA TS3300 Ink Cartridge Replacement
你所需要的
  1. Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: 步骤 1 中的图像 1,2 Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: 步骤 1 中的图像 2,2
    • Press the power button in the top left corner to turn on the printer.
    • The light next to the button will turn green if the printer is on.
  2. Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 2 中的图像 1,2 Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 2 中的图像 2,2
    • Lift the cartridge compartment located in the front of the printer to gain access on the inside of the printer.
    • Allow for the cartridge holder to move into view.
  3. Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 3 中的图像 1,2 Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 3 中的图像 2,2
    • The cartridge should be located in the center of the printer.
    • Push down on the cartridge and pull it out.
  4. Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 4 中的图像 1,2 Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 4 中的图像 2,2
    • Prepare the new cartridge by peeling off the cover.
  5. Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 5 中的图像 1,3 Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 5 中的图像 2,3 Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 5 中的图像 3,3
    • Peel off the orange sticker on the left side of the cartridge.
  6. Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 6 中的图像 1,2 Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 6 中的图像 2,2
    • Insert the cartridge at an angle to the cartridge holder.
    • Push upward on the cartridge until a clicking sound is heard.
  7. Canon PIXMA TS3300 Ink Cartridge Replacement: 步骤 7 中的图像 1,1
    • Close the cartridge compartment cover.
    • The printer should make a sound from the cartridges going back to their resting position.
结论
Allow for the cartridge holder to reposition and you are ready to print!
5等其他人完成本指南。
2条评论
Hi if I replace the ink cartridge with a refill the printer has an error message E16 which I know means cartridge is out of ink. How do I override this message to keep printing. I have a Canon TS3360. Jenny.
Jenny - 回复
My Pixma TS3300 printer is giving an error message E14 since I replaced the empty cartridges with new 245XL and 246XL cartridges. These should be compatible but aren't working. Please help!
Susan Gardner - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 64
过去 30 天: 318
总计 16,962
