跳转到主内容
加入维修社区 - 创建账户
Canon PIXMA MP620B Ink Head Replacement
你所需要的
    1. Canon PIXMA MP620B Ink Head Replacement, Ink Head: 步骤 1 中的图像 1,2 Canon PIXMA MP620B Ink Head Replacement, Ink Head: 步骤 1 中的图像 2,2
      • There are a few tabs on the top of the panel that hook down and into the black side panel. Insert the tool in-between the black panel and the blue panel as shown and pull the two pieces apart.
      • You will hear some snapping. Don't panic: this is just the hooks un-clipping.
      添加评论
    2. Canon PIXMA MP620B Ink Head Replacement: 步骤 2 中的图像 1,2 Canon PIXMA MP620B Ink Head Replacement: 步骤 2 中的图像 2,2
      • Repeat the same process on the left side panel.
      询问修复机器人
      添加评论
    3. Canon PIXMA MP620B Ink Head Replacement: 步骤 3 中的图像 1,1
      • Unhook the lid support by sliding the hook down and to the left. Make sure the support is fully disconnected before proceeding.
      询问修复机器人
      添加评论
    4. Canon PIXMA MP620B Ink Head Replacement: 步骤 4 中的图像 1,2 Canon PIXMA MP620B Ink Head Replacement: 步骤 4 中的图像 2,2
      • Remove the four black screws on the back panels from both the left and right side.
      询问修复机器人
      添加评论
    5. Canon PIXMA MP620B Ink Head Replacement: 步骤 5 中的图像 1,3 Canon PIXMA MP620B Ink Head Replacement: 步骤 5 中的图像 2,3 Canon PIXMA MP620B Ink Head Replacement: 步骤 5 中的图像 3,3
      • Remove the scanner by pulling the side panels out until the scanner pin is free. Set the scanner aside.
      • The scanner will still be attached with wires on the right side. Be careful not to yank the part away from the main body of the printer.
      询问修复机器人
      添加评论
    6. Canon PIXMA MP620B Ink Head Replacement: 步骤 6 中的图像 1,2 Canon PIXMA MP620B Ink Head Replacement: 步骤 6 中的图像 2,2
      • Press down on the clip on the left side of the printer until it clicks, and pull the panel free.
      询问修复机器人
      添加评论
    7. Canon PIXMA MP620B Ink Head Replacement: 步骤 7 中的图像 1,2 Canon PIXMA MP620B Ink Head Replacement: 步骤 7 中的图像 2,2
      • Press down on the clip on the right side panel until it clicks and then pull the panel free.
      询问修复机器人
      添加评论
    8. Canon PIXMA MP620B Ink Head Replacement: 步骤 8 中的图像 1,1
      • Remove the plastic cover by depressing the clip located on the right side of the printer. Press the clip inwards until it clicks, and then lift the cover upwards and off the printer.
      询问修复机器人
      添加评论
    9. Canon PIXMA MP620B Ink Head Replacement, Remove the three screws holding the top rear slider rail: 步骤 9 中的图像 1,2 Canon PIXMA MP620B Ink Head Replacement, Remove the three screws holding the top rear slider rail: 步骤 9 中的图像 2,2
      • Unscrew the three screws holding the rail.
      询问修复机器人
      添加评论
    10. Canon PIXMA MP620B Ink Head Replacement, Remove the guiding cord: 步骤 10 中的图像 1,1
      • Remove the cord by pulling upwards on it and unhooking it from the pulleys on either end.
      询问修复机器人
      添加评论
    11. Canon PIXMA MP620B Ink Head Replacement, Remove the ink head: 步骤 11 中的图像 1,1
      • Remove the ink head by pulling it away from the rail.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G21
4 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 51
总计 3,713
