跳转到主内容
Canon PIXMA MP620B Command Screen Replacement
你所需要的
  1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: 步骤 1 中的图像 1,1
    • Open top lid of the printer to reveal the scanner
  2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: 步骤 2 中的图像 1,2 Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: 步骤 2 中的图像 2,2
    • Insert the spudger tool into the top lid in between the blue and the black panels.
    • Use this tool to pry the two panels apart
  3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: 步骤 3 中的图像 1,1
    • After these two panels are separated, set the top panel to the side for now
  4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: 步骤 4 中的图像 1,1
    • Unplug the two wires shown at the right of the command screen
  5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: 步骤 5 中的图像 1,1
    • Unscrew the four screws shown to detach the command screen from the printer
  6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: 步骤 6 中的图像 1,1
    • Take the detached command screen off of the printer and replace.
结论
4等其他人完成本指南。
Val Fedorikhin
于10/12/14注册
860 声望
创作了5篇指南
团队
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G21
4 名成员
创作了10篇指南
2指南评论
Ideas as to where to buy replacement screen assembly?
davepi49 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,631
