跳转到主内容
Canon PIXMA MP190 Scan Bed Removal
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Canon PIXMA MP190 Scan Bed Removal, Remove Scanning Bed Cover: 步骤 1 中的图像 1,2 Canon PIXMA MP190 Scan Bed Removal, Remove Scanning Bed Cover: 步骤 1 中的图像 2,2
    • Lift scanning bed cover with one hand, and pry the right hinge inward using a plastic opening tool.
    • The cover will lift up and away from the printer.
  2. Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: 步骤 2 中的图像 1,2 Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: 步骤 2 中的图像 2,2
    • Lift the scan bed into the upright position.
    • Ensure the scanning unit support seats into the scanning unit support slot.
    • The four arrow markers located on the bottom edge of the scan bed mark the four tabs that must be released.
  3. Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: 步骤 3 中的图像 1,2 Canon PIXMA MP190 Scan Bed Removal, Accessing Scan Bed: 步骤 3 中的图像 2,2
    • Place a plastic opening tool at each of the four marking arrows.
    • The scan bed will detach from the scan bed unit. Lift scan bed glass upward to access the bottom surface of the glass.
  4. Canon PIXMA MP190 Scan Bed Removal, Cleaning the Scan Bed Glass: 步骤 4 中的图像 1,1
    • Using the screen and device cleaner and cloth remove any dirt or debris from the bottom surface of the scan glass.
  5. Canon PIXMA MP190 Scan Bed Removal, Reassemble Scan Bed Unit: 步骤 5 中的图像 1,2 Canon PIXMA MP190 Scan Bed Removal, Reassemble Scan Bed Unit: 步骤 5 中的图像 2,2
    • Lower the scan bed glass down on to the scanning unit until the clips reengage.
    • Clean the top surface of the scan bed glass using the screen and device cleaner and cloth.
    • Put the scan bed cover back on by placing the left hinge in first.
    • Then snap the right hinge into place.
    • The printer is now ready to scan or copy.
结论
2等其他人完成本指南。
Garret Wescott
于10/23/14注册
597 声望
创作了4篇指南
团队
Michigan Tech, Team 1-5, Lauer Fall 2014 Michigan Tech, Team 1-5, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 423
