当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Orient the camera with the hand strap facing you.
Remove the two 4mm #00 Philips screws.
When the screws are removed, the black plate will easily come off as well as the two metal plates under it. Be careful to not let them fall or get lost.
Remove the plastic cover from the rear of the camcorder by gently pulling it towards you while holding the camera as shown.
The Battery Should be removed at this point, please ignore it in the picture.
Open the LCD by using the release switch.
Reorient the camera with the playback button pad and edge of LCD screen facing you.
Remove the 4mm #00 Phillips screw shown.
Reorient the camera with the top facing you. The side with the LCD screen should be on the right and the other side panel should be on the right.
Open the pop up flash on the top of the camcorder.
A loud clicking noise is expected.
Reorient the camera with the bottom facing you, LCD screen on the right, side panel on the left.
Open the tape deck by sliding the switch and moving the deck cover to the left as shown.
Close the tape deck by gently pushing it toward the body of the camera.
Slide and remove the plastic cover on the bottom right, exposing the interface shown.
Reorient the camera so you are looking at the side of the camera with the viewfinder on the left and lens on the right.
Holding the camera as shown,remove the 4mm #00 Phillips screw.
Reorient the camera with the lens facing you.
Gently pull the side panel of the camera to the right to remove.
Be aware that that there are wires connecting the cover to the body of the device, so the side cover will not come off entirely.
Remove the #00 Philips 3mm screw as shown holding the small circuit board on the side panel.
Hold the side panel and camera together, the orange ribbon cables and their ports are very fragile.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
