当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unhook the plastic panel from the printer starting from the top.
You may need to wiggle the panel a bit to loosen it.
To remove the bottom part of the paneling gently lay the printer on its back.
The scanner lid needs to be supported when moving the printer
Locate the yellow wire connected to the metal box.
Carefully pull the yellow wire from the black connector.
Wires may detach completely from plug so tug very gently.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
