跳转到主内容
Canon ImageCLASS MF4350d Speaker Replacement
你所需要的
  1. Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Front Paneling: 步骤 1 中的图像 1,1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Speaker Replacement: 步骤 2 中的图像 1,2 Canon ImageCLASS MF4350d Speaker Replacement: 步骤 2 中的图像 2,2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Speaker Replacement: 步骤 3 中的图像 1,2 Canon ImageCLASS MF4350d Speaker Replacement: 步骤 3 中的图像 2,2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: 步骤 4 中的图像 1,3 Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: 步骤 4 中的图像 2,3 Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: 步骤 4 中的图像 3,3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Lay printer on its left side for better access to the speaker.
    • Note: The scanner lid needs to be supported when moving the printer
  6. Canon ImageCLASS MF4350d Speaker Replacement: 步骤 6 中的图像 1,2 Canon ImageCLASS MF4350d Speaker Replacement: 步骤 6 中的图像 2,2
    • Locate the black 7mm screw holding the speaker in place.
    • Using a Phillips head screw driver, unscrew the 7mm screw.
  7. Canon ImageCLASS MF4350d Speaker Replacement: 步骤 7 中的图像 1,3 Canon ImageCLASS MF4350d Speaker Replacement: 步骤 7 中的图像 2,3 Canon ImageCLASS MF4350d Speaker Replacement: 步骤 7 中的图像 3,3
    • Locate the red and black wires connected to the speaker.
    • Undo the white clip holding the wires in place by pinching the tab on the top.
    • Remove the red and black wires from the wire bundle.
    • When replacing the old speaker, do not touch any part of the new speaker that is not metal other than the wires. Doing so could damage the speaker.
    • Lift out the speaker
结论
另外一个人完成了本指南。
Helena Yanez
于09/29/13注册
455 声望
创作了4篇指南
团队
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G1
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,364
