跳转到主内容
加入维修社区 - 创建账户
Canon ImageCLASS MF4350d Scanner Disassembly
你所需要的
  1. Canon ImageCLASS MF4350d Scanner Disassembly, Scanner Disassembly: 步骤 1 中的图像 1,1
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 2 中的图像 1,3 Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 2 中的图像 2,3 Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 2 中的图像 3,3
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 3 中的图像 1,3 Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 3 中的图像 2,3 Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 3 中的图像 3,3
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 4 中的图像 1,1
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 5 中的图像 1,2 Canon ImageCLASS MF4350d Scanner Disassembly: 步骤 5 中的图像 2,2
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
结论
5等其他人完成本指南。
团队
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G1
5 名成员
创作了16篇指南
1指南评论
The paper tore and is now not visible. How do I remove the printer's components to access the paper deep in the machine? Is there a method to factory reset the machine? Can I somehow make the rollers rotate to attempt to pushing the paper out?
Kyle - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 36
总计 5,590
