当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
Locate the black and white hinges.
Gently lift out the black and white hinges.
Next, locate and remove the four 10mm screws.
Gently, pry off the top plate, starting from the back of the printer.
After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
Remove the black component by gently pulling it up from the black scanner belt
Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
Take a new belt and put it in the same way that you took it out.
取消:我没有完成这个指南。
与5其他贡献者
于09/30/13注册
560 声望
创作了4篇指南
徽章: 10
+ 7更多徽章
CPSU-FORTE-F13S13G1
5 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,853
