跳转到主内容
Canon ImageCLASS MF4350d Scanner Belt Replacement
你所需要的
  1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Disassembly: 步骤 1 中的图像 1,1
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 2 中的图像 1,3 Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 2 中的图像 2,3 Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 2 中的图像 3,3
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 3 中的图像 1,3 Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 3 中的图像 2,3 Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 3 中的图像 3,3
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 4 中的图像 1,1
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 5 中的图像 1,2 Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 5 中的图像 2,2
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
  6. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: 步骤 6 中的图像 1,2 Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: 步骤 6 中的图像 2,2
    • Remove the black component by gently pulling it up from the black scanner belt
  7. Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 7 中的图像 1,2 Canon ImageCLASS MF4350d Scanner Belt Replacement: 步骤 7 中的图像 2,2
    • Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
    • Take a new belt and put it in the same way that you took it out.
结论
团队
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G1
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,853
