跳转到主内容
Canon EOS Rebel XTi Memory Card Replacement
你所需要的
  1. Canon EOS Rebel XTi Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  2. Canon EOS Rebel XTi Memory Card Replacement: 步骤 2 中的图像 1,1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  3. Canon EOS Rebel XTi Memory Card Replacement: 步骤 3 中的图像 1,1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
结论
Nicholas Abate
于08/28/15注册
656 声望
创作了5篇指南
团队
USF Tampa, Team 8-6, Eyestone Fall 2015 USF Tampa, Team 8-6, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G6
3 名成员
创作了18篇指南
一条评论
My camara wont read memory card
mcbed215 - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 19
总计 3,292
