跳转到主内容
Canon EOS Rebel XSi Mother Board Replacement
你所需要的
  1. Canon EOS Rebel XSi Mother Board Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Mother Board Replacement: 步骤 2 中的图像 1,1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Mother Board Replacement: 步骤 3 中的图像 1,1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Mother Board Replacement: 步骤 4 中的图像 1,1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Mother Board Replacement: 步骤 5 中的图像 1,1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Mother Board Replacement: 步骤 6 中的图像 1,1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Mother Board Replacement: 步骤 7 中的图像 1,1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Mother Board Replacement: 步骤 8 中的图像 1,1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Mother Board Replacement, Mother Board: 步骤 9 中的图像 1,1
    • Using the PH00 screwdriver head, unscrew the three 3mm screws.
  10. Canon EOS Rebel XSi Mother Board Replacement: 步骤 10 中的图像 1,1
    • Disconnect the five cables attached to the motherboard by gently pulling with tweezers.
  11. Canon EOS Rebel XSi Mother Board Replacement: 步骤 11 中的图像 1,1
    • Remove tab from base by lifting up with finger.
  12. Canon EOS Rebel XSi Mother Board Replacement: 步骤 12 中的图像 1,1
    • Using the PH00 screwdriver head, unscrew the three 3mm screws on the left side of the camera.
  13. Canon EOS Rebel XSi Mother Board Replacement: 步骤 13 中的图像 1,1
    • Using the PH00 screwdriver head, unscrew the last 4mm screw from the motherboard.
  14. Canon EOS Rebel XSi Mother Board Replacement: 步骤 14 中的图像 1,2 Canon EOS Rebel XSi Mother Board Replacement: 步骤 14 中的图像 2,2
    • Remove motherboard by gently lifting out with fingers.
结论
3等其他人完成本指南。
Erik Mork
于01/27/17注册
596 声望
创作了5篇指南
团队
Cal Poly, Team 22-10, Maness Winter 2017 Cal Poly, Team 22-10, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G10
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 38
总计 1,994
