跳转到主内容
Canon EOS Rebel XSi Daughter Board Replacement
你所需要的
  1. Canon EOS Rebel XSi Daughter Board Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 2 中的图像 1,1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 3 中的图像 1,1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 4 中的图像 1,1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 5 中的图像 1,1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 6 中的图像 1,1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 7 中的图像 1,1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 8 中的图像 1,1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Daughter Board Replacement, Front Panel: 步骤 9 中的图像 1,1
    • Using the PH000 screwdriver head, remove the four 3mm screws on the front
  10. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 10 中的图像 1,1
    • Remove front grip by gently peeling from the edge towards the center of the camera
  11. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 11 中的图像 1,1
    • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
  12. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 12 中的图像 1,1
    • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
  13. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 13 中的图像 1,3 Canon EOS Rebel XSi Daughter Board Replacement: 步骤 13 中的图像 2,3 Canon EOS Rebel XSi Daughter Board Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
  14. Canon EOS Rebel XSi Daughter Board Replacement, Daughter Board: 步骤 14 中的图像 1,1
    • Using the PH000 screwdriver head, remove the three 3mm screws
  15. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 15 中的图像 1,1
    • Carefully remove the cable from its plastic base with fingers
  16. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 16 中的图像 1,1
    • Gently slide board out with thumb
  17. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 17 中的图像 1,1
    • Gently disconnect cable by pulling out from plastic base with fingers
  18. Canon EOS Rebel XSi Daughter Board Replacement: 步骤 18 中的图像 1,1
    • Disconnect cables by pulling out from base with fingers
结论
3等其他人完成本指南。
Erik Mork
于01/27/17注册
602 声望
创作了5篇指南
团队
Cal Poly, Team 22-10, Maness Winter 2017 Cal Poly, Team 22-10, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G10
4 名成员
创作了10篇指南
一条评论
what does this fix
djratlif - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 23
过去 30 天: 31
总计 1,407
