跳转到主内容
Canon EOS Rebel XS Lens Mount Ring Replacement
你所需要的
  1. Canon EOS Rebel XS Lens Mount Ring Replacement, Latch Side Cover: 步骤 1 中的图像 1,1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Lens Mount Ring Replacement: 步骤 2 中的图像 1,1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Lens Mount Ring Replacement, Disassembling Canon EOS Rebel XS Front Cover: 步骤 3 中的图像 1,1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Lens Mount Ring Replacement: 步骤 4 中的图像 1,1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Lens Mount Ring Replacement, Canon EOS Rebel XS Lens Mount Ring Replacement: 步骤 5 中的图像 1,1
    • Remove the five silver screws from the lens mounting ring using a Phillips screwdriver.
  6. Canon EOS Rebel XS Lens Mount Ring Replacement: 步骤 6 中的图像 1,1
    • Use your fingers to remove the lens mounting ring.
    • There is a small metal button housed in the ring (red square). Be careful not to lose this piece when removing the ring.
  7. Canon EOS Rebel XS Lens Mount Ring Replacement: 步骤 7 中的图像 1,1
    • Use a pair of tweezers to remove the spring on the lens mounting ring.
  8. Canon EOS Rebel XS Lens Mount Ring Replacement: 步骤 8 中的图像 1,1
    • Use a pair of tweezers to remove the gold metal ring.
    • Take note of the ring's orientation for re-installing it.
结论
3等其他人完成本指南。
Daniel Bussone
于01/28/11注册
1,251 声望
创作了11篇指南
团队
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G41
2 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 7,600
