跳转到主内容
Canon EOS Rebel XS LCD Replacement
你所需要的
  1. Canon EOS Rebel XS LCD Replacement, Latch Side Cover: 步骤 1 中的图像 1,1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS LCD Replacement: 步骤 2 中的图像 1,1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS LCD Replacement, Back Cover: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  4. Canon EOS Rebel XS LCD Replacement: 步骤 4 中的图像 1,1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  5. Canon EOS Rebel XS LCD Replacement, LCD: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the tweezers to gently remove the straps (in the teal box).
    • Use the Phillips Screwdriver to remove the four screws (in the red dots).
    • Use your fingers to remove the silver plate.
  6. Canon EOS Rebel XS LCD Replacement: 步骤 6 中的图像 1,1
    • Use the Spudger on the edges of the screen.
    • Once one end is lose, use the tweezers to lift the screen.
结论
3等其他人完成本指南。
Daniel Bussone
于01/28/11注册
1,264 声望
创作了11篇指南
团队
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G41
2 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 7,497
