跳转到主内容
Canon EOS Rebel XS Grip Replacement
你所需要的
  1. Canon EOS Rebel XS Grip Replacement, Latch Side Cover: 步骤 1 中的图像 1,1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Grip Replacement: 步骤 2 中的图像 1,1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Grip Replacement, Disassembling Canon EOS Rebel XS Front Cover: 步骤 3 中的图像 1,1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Grip Replacement: 步骤 4 中的图像 1,1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Grip Replacement, Grip: 步骤 5 中的图像 1,1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Canon EOS Rebel XS Grip Replacement: 步骤 6 中的图像 1,1
    • Use your fingertip to pry off the external shutter port cover.
  7. Canon EOS Rebel XS Grip Replacement: 步骤 7 中的图像 1,1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Canon EOS Rebel XS Grip Replacement: 步骤 8 中的图像 1,3 Canon EOS Rebel XS Grip Replacement: 步骤 8 中的图像 2,3 Canon EOS Rebel XS Grip Replacement: 步骤 8 中的图像 3,3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Canon EOS Rebel XS Grip Replacement: 步骤 9 中的图像 1,1
    • Once the grip is loose, use your fingers to remove it from the camera.
结论
另外一个人完成了本指南。
Daniel Bussone
于01/28/11注册
1,251 声望
创作了11篇指南
团队
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G41
2 名成员
创作了21篇指南
一条评论
Little confused. Some pics are from a analog Canon, other from a digital Canon...
Gustavo Aguiar - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 3,555
