跳转到主内容
Canon EOS Rebel XS 35mm Top Cover Replacement
你所需要的
  1. Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: 步骤 1 中的图像 1,2 Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Top Cover Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Top Cover Replacement: 步骤 3 中的图像 1,1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Top Cover Replacement: 步骤 4 中的图像 1,3 Canon EOS Rebel XS 35mm Top Cover Replacement: 步骤 4 中的图像 2,3 Canon EOS Rebel XS 35mm Top Cover Replacement: 步骤 4 中的图像 3,3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
结论
另外一个人完成了本指南。
christiansvezia
于10/24/18注册
1,108 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 293
