跳转到主内容
Canon EOS Rebel XS 35mm Lens Replacement
你所需要的
  1. Canon EOS Rebel XS 35mm Lens Replacement, Top Cover: 步骤 1 中的图像 1,2 Canon EOS Rebel XS 35mm Lens Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Replacement: 步骤 3 中的图像 1,1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Lens Replacement: 步骤 4 中的图像 1,3 Canon EOS Rebel XS 35mm Lens Replacement: 步骤 4 中的图像 2,3 Canon EOS Rebel XS 35mm Lens Replacement: 步骤 4 中的图像 3,3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm Lens Replacement, Lens: 步骤 5 中的图像 1,1
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 8 mm in length and 1.5 mm in diameter.
  6. Canon EOS Rebel XS 35mm Lens Replacement: 步骤 6 中的图像 1,1
    • Using your fingers, remove the lens!
结论
christiansvezia
于10/24/18注册
1,136 声望
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 377
