跳转到主内容
Canon EOS Rebel XS 35mm Lens Mount Parts Replacement
你所需要的
  1. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement, Lens Mount Parts: 步骤 1 中的图像 1,1
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 6 mm in length and 1.25 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 步骤 2 中的图像 1,1
    • Using a PH000 screwdriver bit, remove the 5 black screws circled in the picture, which are all 5.5 mm in length and 2 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Simply using your fingers - although you can use something else such as tweezers - remove the first layer of the lens mount. This first layer is black, plastic, has a red dot at the top, and so on.
  4. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 步骤 4 中的图像 1,1
    • Using (preferably) tweezers - although you can also use your fingers - remove the flimsy brass-colored layer of the lens mount.
  5. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: 步骤 5 中的图像 1,1
    • Using (preferably) tweezers - although you can also use your fingers - remove the silver layer of the lens mount.
结论
Reassembly can be a lot harder than disassembly for this part of the camera, which accounts for the large range in estimated time.
christiansvezia
于10/24/18注册
1,108 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 17
总计 382
