跳转到主内容
Canon EOS Rebel XS 35mm LCD screen Replacement
你所需要的
  1. Canon EOS Rebel XS 35mm LCD screen Replacement, Top Cover: 步骤 1 中的图像 1,2 Canon EOS Rebel XS 35mm LCD screen Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 3 中的图像 1,1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 4 中的图像 1,3 Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 4 中的图像 2,3 Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 4 中的图像 3,3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm LCD screen Replacement, LCD screen: 步骤 5 中的图像 1,1
    • Using a PH000 screwdriver bit, remove the tiny silver screw circled in the picture, which is 2 mm in length and 1 mm in diameter.
  6. Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • With your fingers or tweezers, remove the brass-colored part.
  7. Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 7 中的图像 1,2 Canon EOS Rebel XS 35mm LCD screen Replacement: 步骤 7 中的图像 2,2
    • With your fingers (probably not tweezers or something similar, so you don't damage the screen), remove the LCD screen.
结论
christiansvezia
于10/24/18注册
1,136 声望
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 453
