跳转到主内容
Canon EOS Rebel XS 35mm Bottom Cover and More Replacement
你所需要的
  1. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 2 中的图像 1,1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 3 中的图像 1,1
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
  4. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover and More: 步骤 4 中的图像 1,1
    • Remove the 5mm silver Phillips #000 screw.
    • Remove three 4mm Phillips #000 screws.
  5. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 5 中的图像 1,1
    • Remove the silver plate with tweezers or fingers.
  6. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 6 中的图像 1,1
    • Be mindful of the spring attached to the plastic piece. Do not lose it.
    • Remove the plastic black part.
  7. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 7 中的图像 1,1
    • Remove the black gear with tweezers or fingers.
  8. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 8 中的图像 1,1
    • Remove the gear with tweezers or fingers.
  9. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 9 中的图像 1,1
    • Remove the part indicated in the picture with tweezers or fingers.
  10. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 10 中的图像 1,1
  11. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 11 中的图像 1,1
  12. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 12 中的图像 1,2 Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 12 中的图像 2,2
    • Remove two 3mm Phillips #000 screws.
    • Remove two silver 3.5mm Phillips #000 screws.
  13. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: 步骤 13 中的图像 1,1
    • Remove the second silver plate using tweezers or fingers.
结论
christiansvezia
于10/24/18注册
1,108 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 320
