跳转到主内容
Canon EOS Rebel XS 35mm Back Latch Replacement
你所需要的
  1. Canon EOS Rebel XS 35mm Back Latch Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 2 中的图像 1,1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
  4. Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: 步骤 4 中的图像 1,2 Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: 步骤 4 中的图像 2,2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  5. Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  6. Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 6 中的图像 1,1
    • Pull off the front cover.
  7. Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 7 中的图像 1,3 Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 7 中的图像 2,3 Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 7 中的图像 3,3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  8. Canon EOS Rebel XS 35mm Back Latch Replacement, Back Latch: 步骤 8 中的图像 1,1
    • Once the front, top, and bottom covers have all been removed, it's time to remove the back latch! Using a paperclip or something similar (anything that's very skinny), push on the end of the skinny, silver, metal rod that vertically travels through the camera. Do this until enough of the rod pops out on the other side for the next step.
  9. Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 11 中的图像 1,2 Canon EOS Rebel XS 35mm Back Latch Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • With a pair of tweezers or just your fingers, pull the rod completely out of the camera. The back latch should then completely detach from the camera.
结论
christiansvezia
于10/24/18注册
1,108 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 631
