简介
Use this guide to remove and replace the PCB flashboard from your Canon EOS Rebel T6i camera. The PCB flashboard should be replaced following damage or exposure to the capacitor and/or the circuit itself. This is a step-by-step guide and each step should be followed in chronological order to ensure desired results.
You will need an iFixit opening tool, a spudger, a JIS #000 screwdriver, needle-nosed tweezers, a grounding strap, and a digital multimeter to complete the removal process.
Take caution when unassembling your Canon EOS Rebel T6i device. There is potential for device damage during the unassembling process.
**CAUTION(Electric Shock): Be careful not to touch the terminals of the capacitor (black cylinder). This can cause the capacitor to discharge.
你所需要的
Remove two 6.8 mm JIS #000 screws on the right side.
Remove six 5.3 mm JIS #000 screws on the bottom.
Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
Remove the button cell battery from the motherboard using a pair of tweezers.
Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
Remove the four screws from the bottom of the camera.
Remove the entire upper flash assembly by gently pulling it up and off the camera.
What is the black wire-looking thing that hangs down from the flash/top cover assy? Doesnt have a connector on it, seems to be made of rubber. It goes up to the built-in flash head and seems to be epoxied to it. WiFi antenna? Doesnt really make sense bevause its not attached to the mainboard as far as I can tell. In the second picture above, it is the black thing hanging down in front od the underside of the dial.
Where does that go when you put it back together?
Disconnect the ribbon connector on the upper right side of the motherboard.
Pull back the foam on the connector on the far right side of the motherboard.
Flip up the tab on the connector and remove the cable.
Place a voltmeter in parallel with the capacitor. If a charge is detected, make sure the battery is removed from the device.
另外一个人完成了本指南。
