简介
This guide will show how to get to and replace the motherboard.
你所需要的
Remove two 6.8 mm JIS #000 screws on the right side.
Remove six 5.3 mm JIS #000 screws on the bottom.
Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
Remove the button cell battery from the motherboard using a pair of tweezers.
Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
Remove the four screws from the bottom of the camera.
Remove the entire upper flash assembly by gently pulling it up and off the camera.
What is the black wire-looking thing that hangs down from the flash/top cover assy? Doesnt have a connector on it, seems to be made of rubber. It goes up to the built-in flash head and seems to be epoxied to it. WiFi antenna? Doesnt really make sense bevause its not attached to the mainboard as far as I can tell. In the second picture above, it is the black thing hanging down in front od the underside of the dial.
Where does that go when you put it back together?
Disconnect the ribbon connector on the upper right side of the motherboard.
Pull back the foam on the connector on the far right side of the motherboard.
Flip up the tab on the connector and remove the cable.
7等其他人完成本指南。
2条评论
Good tutorial! Two things I noticed on my teardown, on step 6 the white grounding wire has two black tabs on either side you can lift with a guitar pick, much better than pulling on the wire casing; on step 12 the picture is misleading as you pull the plug out towards the middle of the body. Those are very minor things, this was an extremely helpful tutorial! Not for the faint of heart aha
