跳转到主内容
Canon EOS Rebel T6i LCD Display Replacement
你所需要的
    • Remove battery and ground your wrist using a grounding strap to prevent damage to device.
  1. Canon EOS Rebel T6i LCD Display Replacement: 步骤 2 中的图像 1,1
    • 2 screws on the side -1.3 mm
  2. Canon EOS Rebel T6i LCD Display Replacement: 步骤 3 中的图像 1,2 Canon EOS Rebel T6i LCD Display Replacement: 步骤 3 中的图像 2,2
    • 4 screws are located on the opposite/interior side of screen case. Use the J000 gauge screw driver head to remove these 4 screws. Furthermore, these screws are a larger gauge then the other 2. Please sort these accordingly.
    • 4 small screws on back 1.58 mm
  3. Canon EOS Rebel T6i LCD Display Replacement: 步骤 4 中的图像 1,2 Canon EOS Rebel T6i LCD Display Replacement: 步骤 4 中的图像 2,2
    • Following the removal of the 6 screws, Locate the joint of the casing. Place a flat lever inside this crevice and apply pressure. The case should simply pop open into the 2 casing pieces and the screen mechanism. Warning. No Dot try to remove bottom casing until next step.
  4. Canon EOS Rebel T6i LCD Display Replacement: 步骤 5 中的图像 1,3 Canon EOS Rebel T6i LCD Display Replacement: 步骤 5 中的图像 2,3 Canon EOS Rebel T6i LCD Display Replacement: 步骤 5 中的图像 3,3
    • There are several components inside the casing. A board, a power cable, the screen and a ribbon cable. First, using tweezers lift the metallic clamp connecting the ribbon to the board.
    • WARNING. If the lever doesn't lift immediately, do not forcefully lift it. This could damage the ribbon and board. When reapplying the ribbon, secure connection.
  5. Canon EOS Rebel T6i LCD Display Replacement: 步骤 6 中的图像 1,1
    • Now that the ribbon is disconnected, remove the board carefully and place it aside. This piece still works so leave it attached to camera.
  6. Canon EOS Rebel T6i LCD Display Replacement: 步骤 7 中的图像 1,2 Canon EOS Rebel T6i LCD Display Replacement: 步骤 7 中的图像 2,2
    • The screen is glued into the casing. Remove the screen by carefulyl lifting along the edges of the case until the screen pops out. Place new screen into the existing casing. A small about of glue or adhesive may be necessary if their isn't sufficient adhesive remaining in the case. Repeat steps in reverse to reapply screen.
  7. Canon EOS Rebel T6i LCD Display Replacement: 步骤 8 中的图像 1,1
    • If screen doesn't power on after replacing the battery, Go back and check connections of the ribbon.
结论
另外一个人完成了本指南。
3条评论
Very simple and great guide for. See the Canon T6i Bundle
Deve Lee - 回复
Thanks for this awesome guide its really useful for me. see the Canon 80D Bundle
9 Product Reviews - 回复
y las refacciones donde?
cafeplazay - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 9
过去 30 天: 33
总计 3,946
