跳转到主内容
Canon EOS Rebel T6i Flash Assembly Replacement
你所需要的
  1. Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 1,3 Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 2,3 Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 3,3
    • Remove two 6.8 mm JIS #000 screws on the right side.
    • Remove six 5.3 mm JIS #000 screws on the bottom.
    • Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
  2. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove one 5.9 mm JIS #000 screw on the top right.
    • Remove one 3.4 mm JIS #000 screw on the top left.
  3. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 3 中的图像 3,3
    • Using a metal spudger, pry the rubber grip off of the casing on the left side of the camera.
    • Potential for device damage: Be careful not to rip the rubber with the metal spudger.
    • Remove five silver 5.8 mm JIS #000 screws from underneath the grip.
  4. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 4 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 4 中的图像 2,2
    • Using the metal spudger, pry the rubber grip located just below the turndial.
    • Potential for device damage: Be careful not to rip the rubber.
  5. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 5 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 5 中的图像 2,2
    • Carefully use the plastic opening tool to pry the casing apart along the seam.
    • Follow the seam with the plastic tool until the back is ready to remove.
    • Potential for device damage: Make sure you use the grounding strip to remove the chance of discharging static electricity into the internal components.
  6. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 6 中的图像 1,3 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 6 中的图像 2,3 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 6 中的图像 3,3
    • Notice the two connections attaching the back of the camera to the motherboard.
    • To disconnect the white wire, pinch the wire casing and pull it directly out from the camera.
    • This may take a very small amount of strength; however, do not force or pry it.
    • To disconnect the ribbon connector, softly pull the back away from the motherboard. It should come undone with little force.
    • Once removed, set the back in a safe place.
  7. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 7 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
    • Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
  8. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 8 中的图像 1,1
    • Remove the button cell battery from the motherboard using a pair of tweezers.
  9. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 9 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 9 中的图像 2,2
    • Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
    • Disconnect the three ribbon connectors along the top.
    • Don't detach the connectors underneath or the ribbon connectors with the foam block, as these will be removed later.
  10. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 10 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 10 中的图像 2,2
    • Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
    • Remove the four screws from the bottom of the camera.
  11. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 11 中的图像 1,3 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 11 中的图像 2,3 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 11 中的图像 3,3
    • Using the plastic opening tool, pry the front of the casing off of the camera.
    • Warning: Electric Shock! Be careful not to touch the terminals of the capacitor (black cylinder). This can cause the capacitor to discharge.
  12. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 12 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 12 中的图像 2,2
    • Remove the yellow and red connections on the front near the black cylinder (capacitor).
    • The yellow connector will just pop out if pried from the bottom using a plastic opening tool.
    • The red connector will pull out of the casing with either a plastic opening tool or a thin set of tweezers.
  13. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 13 中的图像 1,1
    • Remove the diopter adjustment knob next to the viewfinder using a JIS #000 screwdriver.
  14. Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 14 中的图像 1,2 Canon EOS Rebel T6i Flash Assembly Replacement: 步骤 14 中的图像 2,2
    • Remove the entire upper flash assembly by gently pulling it up and off the camera.
    • The flash assembly is sold as a single piece.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 49
总计 3,723
