简介
If you find that your camera's motherboard has failed, and needs to be replaced, this guide will show you the steps necessary to complete this task.
你所需要的
Lay the camera on its back so that the card/battery door is facing you.
Using your fingernail, slide the tab on the battery door up to release the battery door latch.
Turn the camera so that the back is facing to your right.
Remove the 5mm Phillips #000 screw above the rubber USB port cover.
Remove all ribbon cables with the plastic spudger.
Gently pry up the black plastic tabs to slide out the ribbon cables
9等其他人完成本指南。
2条评论
This guide is amazing, but if you change the mainboard do you have to initialize it by software, like Spt?
New main board from canon .
How to instalize?
