简介
Whether you have a faulty battery, or would simply like to carry around a few extra for an extended outing, this guide will show you how to switch them out.
你所需要的
Lay the camera on its back so that the card/battery door is facing you.
Using your fingernail, slide the tab on the battery door up to release the battery door latch.
5等其他人完成本指南。
一条评论
amigos saludos cordiales.
tengo un problema con mi canon t5 vi que le rompio o desprendio un pin de la parte de donde labateria encaja dentro de la camara la idea es como conectarla o soldarla? o repararla ls agradesco su atencion.
