跳转到主内容
Canon EOS Rebel T4i Motherboard Replacement
你所需要的
  1. Canon EOS Rebel T4i Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Motherboard Replacement: 步骤 2 中的图像 1,1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Use the spudger to pry off the rubber grip and reveal the screws.
    • Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
  4. Canon EOS Rebel T4i Motherboard Replacement: 步骤 4 中的图像 1,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 4 中的图像 2,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pull off the plastic cover from the viewfinder.
    • Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver.
  5. Canon EOS Rebel T4i Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the following screws from the device using the Phillips #00 screwdriver:
    • Two 3.4mm Phillips head screws.
    • Two 5.9mm Phillips head screw.
    On my camera, both the outer screews were 5.9 mm long.
    Geir Atle Storhaug - 回复
    I can confirm the comment from 03/14/2015: Both outer screews are long.
    Erikk - 回复
  6. Canon EOS Rebel T4i Motherboard Replacement: 步骤 6 中的图像 1,1
    • One 3.4mm Phillips head screw.
    • One 5.9 mm Phillips head screw.
  7. Canon EOS Rebel T4i Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the rear panel from the camera.
    • Several fragile cables are attached to the inside of the panel, so remove it gently.
  8. Canon EOS Rebel T4i Motherboard Replacement: 步骤 8 中的图像 1,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 8 中的图像 2,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 8 中的图像 3,3
    • In the lower right corner of the mother board, detach the blue cable.
    • Then detach the ribbon cable going from the motherboard to the rear panel.
  9. Canon EOS Rebel T4i Motherboard Replacement: 步骤 9 中的图像 1,1
    • In the upper left corner of the motherboard, remove the small multicolored wire from the motherboard.
  10. Canon EOS Rebel T4i Motherboard Replacement: 步骤 10 中的图像 1,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 10 中的图像 2,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 10 中的图像 3,3
    • Use the plastic opening tool to flip up ribbon cable connector.
    • Gently disconnect the ribbon cable by pulling it away from the motherboard.
  11. Canon EOS Rebel T4i Motherboard Replacement: 步骤 11 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 11 中的图像 2,2
    • In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard.
  12. Canon EOS Rebel T4i Motherboard Replacement: 步骤 12 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard.
  13. Canon EOS Rebel T4i Motherboard Replacement: 步骤 13 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 13 中的图像 2,2
    • Use the plastic opening tool to push on the indents of the plastic header to disconnect from the motherboard.
    • Make sure all cables are disconnected from the motherboard.
  14. Canon EOS Rebel T4i Motherboard Replacement: 步骤 14 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove the following screws from the motherboard using the Phillips #00 screwdriver:
    • Two 3.9mm Phillips head screws.
    • Three 2.9mm Phillips head screws
    • Gently pull the motherboard out of the camera.
    I was wondering how did you get to loosen the 3.9mm Phillips screw on the top right.
    lucato - 回复
    Fixed that, the orange marker was a bit off, it was on an alignment pin instead of the actual screw which was just a bit more to the right.
    Flying Dutchman -
    I cannot reach the 3.9mm screw with any tool because it is underneath of the plastic body that holds the zoom +/- buttons. How old you remove that top right motherboard screw?
    Jeff Ramsey - 回复
    I hate to bring up an old question, but did you ever manage to get this screw off with your camera? I am working on mine yet I am about to simply drill through the plastic under the zoom buttons.
    jeremy cohan -
    You have to remove the top part of the camera body to reach the screw. It is also much easier to reconnect flat cables.
    Max - 回复
    Where can I find a replacement board. I cannot find one anywhere!
    Matt Jones - 回复
    Same here, how to remove this top-right orange 3.9mm phillips screw?
    If top has to be removed, how to do that? It’s not visually obvious to me at the moment.
    Also, really where to get the replacement MB?
    Giorgi - 回复
    That last top-right screw is actually impossible to remove - need to take off the top cover. Follow this guide:
    Canon EOS Rebel T3i Top Casing Replacement
    Giorgi - 回复
结论
16等其他人完成本指南。
Jordan Rabold
于04/14/14注册
774 声望
创作了3篇指南
团队
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G33
4 名成员
创作了14篇指南
2条评论
This guide gets an upvote.
It's the first camera disassembly guide I've seen so far on ifixit that includes the single most important precaution: the camera has a body cap fitted to avoid dust, dirt or other objects getting into the mirror box. Bravo!
Flying Dutchman - 回复
Where can we buy the parts?
tjt263 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 52
总计 14,090
