跳转到主内容
Canon EOS Rebel T4i Motherboard Replacement
你所需要的
  1. Canon EOS Rebel T4i Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Motherboard Replacement: 步骤 2 中的图像 1,1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Use the spudger to pry off the rubber grip and reveal the screws.
    • Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
  4. Canon EOS Rebel T4i Motherboard Replacement: 步骤 4 中的图像 1,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 4 中的图像 2,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pull off the plastic cover from the viewfinder.
    • Unscrew the two 3.4mm Phillips screws using the Phillips #00 screwdriver.
  5. Canon EOS Rebel T4i Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the following screws from the device using the Phillips #00 screwdriver:
    • Two 3.4mm Phillips head screws.
    • Two 5.9mm Phillips head screw.
  6. Canon EOS Rebel T4i Motherboard Replacement: 步骤 6 中的图像 1,1
    • One 3.4mm Phillips head screw.
    • One 5.9 mm Phillips head screw.
  7. Canon EOS Rebel T4i Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the rear panel from the camera.
    • Several fragile cables are attached to the inside of the panel, so remove it gently.
  8. Canon EOS Rebel T4i Motherboard Replacement: 步骤 8 中的图像 1,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 8 中的图像 2,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 8 中的图像 3,3
    • In the lower right corner of the mother board, detach the blue cable.
    • Then detach the ribbon cable going from the motherboard to the rear panel.
  9. Canon EOS Rebel T4i Motherboard Replacement: 步骤 9 中的图像 1,1
    • In the upper left corner of the motherboard, remove the small multicolored wire from the motherboard.
  10. Canon EOS Rebel T4i Motherboard Replacement: 步骤 10 中的图像 1,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 10 中的图像 2,3 Canon EOS Rebel T4i Motherboard Replacement: 步骤 10 中的图像 3,3
    • Use the plastic opening tool to flip up ribbon cable connector.
    • Gently disconnect the ribbon cable by pulling it away from the motherboard.
  11. Canon EOS Rebel T4i Motherboard Replacement: 步骤 11 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 11 中的图像 2,2
    • In the upper right corner of the motherboard, use the plastic opening tool to remove the clear cable connector from the motherboard.
  12. Canon EOS Rebel T4i Motherboard Replacement: 步骤 12 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 12 中的图像 2,2
    • Use the plastic opening tool to remove the ribbon cable connecting the image sensor to the motherboard.
  13. Canon EOS Rebel T4i Motherboard Replacement: 步骤 13 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 13 中的图像 2,2
    • Use the plastic opening tool to push on the indents of the plastic header to disconnect from the motherboard.
    • Make sure all cables are disconnected from the motherboard.
  14. Canon EOS Rebel T4i Motherboard Replacement: 步骤 14 中的图像 1,2 Canon EOS Rebel T4i Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove the following screws from the motherboard using the Phillips #00 screwdriver:
    • Two 3.9mm Phillips head screws.
    • Three 2.9mm Phillips head screws
    • Gently pull the motherboard out of the camera.
结论
16等其他人完成本指南。
Jordan Rabold
于04/14/14注册
783 声望
创作了3篇指南
团队
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G33
4 名成员
创作了14篇指南
2条评论
This guide gets an upvote.
It's the first camera disassembly guide I've seen so far on ifixit that includes the single most important precaution: the camera has a body cap fitted to avoid dust, dirt or other objects getting into the mirror box. Bravo!
Flying Dutchman - 回复
Where can we buy the parts?
tjt263 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 63
总计 14,261
