简介
This guide will detail the process of replacing the motherboard. Replacing the motherboard is a more involved process and should not be done unless your are sure there is an issue with the motherboard.
你所需要的
Locate the battery cover at the bottom of the camera.
Pull down on the black tab to open the cover.
Use the spudger to pry off the rubber grip and reveal the screws.
Unscrew the four 5.5mm Torx screws using the Torx T6 screwdriver.
16等其他人完成本指南。
2条评论
This guide gets an upvote.
It's the first camera disassembly guide I've seen so far on ifixit that includes the single most important precaution: the camera has a body cap fitted to avoid dust, dirt or other objects getting into the mirror box. Bravo!
