跳转到主内容
Canon EOS Rebel T4i Flash Replacement
你所需要的
  1. Canon EOS Rebel T4i Flash Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Flash Replacement: 步骤 2 中的图像 1,1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i Flash Replacement, Flash: 步骤 3 中的图像 1,1
    • Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
  4. Canon EOS Rebel T4i Flash Replacement: 步骤 4 中的图像 1,1
    • Remove the covering.
  5. Canon EOS Rebel T4i Flash Replacement: 步骤 5 中的图像 1,1
    • Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
  6. Canon EOS Rebel T4i Flash Replacement: 步骤 6 中的图像 1,1
    • Use the wire cutters to cut the wiring connected to the flash.
结论
9等其他人完成本指南。
Jordan Rabold
于04/14/14注册
774 声望
创作了3篇指南
团队
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G33
4 名成员
创作了14篇指南
3条评论
how do you reverse step 6 - cutting the wires?
jeremyyoung - 回复
You dont tell how to make sure capacitors are discharged before changing the flash ? and do you know what is the replacement number of the flash bulb itself ?
jackqc09 - 回复
No parts required? So I can repair my flash not having to buy a new bulb? haha Please, I need the link from where I repair my burned built-in flash :/
gustavoaleme - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 4,358
