跳转到主内容
Canon EOS Rebel T4i Battery Replacement
  1. Canon EOS Rebel T4i Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i Battery Replacement: 步骤 2 中的图像 1,1
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
结论
3等其他人完成本指南。
Nimisha Patel
于04/14/14注册
164 声望
撰写一个指南
团队
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G33
4 名成员
创作了14篇指南
一条评论
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
esther allwood - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 3,131
