简介
Use this guide to replace the front casing on your Canon EOS Rebel T3i.
你所需要的
Remove the four 5 mm Phillips #000 screws.
The 6mm screw would sit in the bottom right hole, if it has this one longer screw.
Lift off the USB cover.
Make sure the viewfinder eyepiece is removed, otherwise it will hold the top left corner of the back part in place.
5等其他人完成本指南。
一条评论
when I connect and lens the camera replies that the lens is properly connected. One of the copper lens connectors on the camera’s body is kinda greenish rather than gold, so I wanna clean it, how to do that?
