跳转到主内容
Canon EOS Rebel T2i Tripod Mount Replacement
你所需要的
  1. Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: 步骤 1 中的图像 1,2 Canon EOS Rebel T2i Tripod Mount Replacement, Tripod Mount: 步骤 1 中的图像 2,2
    • Turn off camera using the power button on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 2 中的图像 1,1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws on the right side of the camera.
  4. Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 4 中的图像 1,1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two silver screws.
  5. Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 5 中的图像 1,1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  6. Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 6 中的图像 1,2 Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 6 中的图像 2,2
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
  7. Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 7 中的图像 1,1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  8. Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 8 中的图像 1,2 Canon EOS Rebel T2i Tripod Mount Replacement: 步骤 8 中的图像 2,2
    • The screws holding the tripod mount are now exposed.
    • Remove the screws securing the tripod mount
    • With the screws removed, the tripod mount can now be easily pulled free.
结论
Jacob Jaskolka
于03/30/15注册
745 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-1, Shastany Spring 2015 UMass Dartmouth, Team 1-1, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S1G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,679
