跳转到主内容
Canon EOS Rebel T2i Top Casing Replacement
你所需要的
  1. Canon EOS Rebel T2i Top Casing Replacement, Remove the battery.: 步骤 1 中的图像 1,2 Canon EOS Rebel T2i Top Casing Replacement, Remove the battery.: 步骤 1 中的图像 2,2
    • Remove the battery using the 00 screwdriver.
    • Remove the neck strap
    • Remove the plastic casing around the viewing lens
  2. Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: 步骤 2 中的图像 1,3 Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: 步骤 2 中的图像 2,3 Canon EOS Rebel T2i Top Casing Replacement, Remove the back casing.: 步骤 2 中的图像 3,3
    • Remove these screws.
  3. Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: 步骤 3 中的图像 1,3 Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: 步骤 3 中的图像 2,3 Canon EOS Rebel T2i Top Casing Replacement, Remove the front casing..: 步骤 3 中的图像 3,3
  4. Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: 步骤 4 中的图像 1,3 Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: 步骤 4 中的图像 2,3 Canon EOS Rebel T2i Top Casing Replacement, Remove the top casing.: 步骤 4 中的图像 3,3
    • Remove the screws below the view finder.
    • Remove the screw of the focus wheel right from the view finder using the 000 screw driver
    • Remove the top screws.
    • Using your fingers, remove the left wire connecting the microphone.
  5. Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: 步骤 5 中的图像 1,3 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: 步骤 5 中的图像 2,3 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing continued.: 步骤 5 中的图像 3,3
    • Use your fingers to complete the following steps. Remove the black wire beneath the power switch.
    • Remove the wire on the left side shown.
    • Remove the two ribbon wires on the right side.
  6. Canon EOS Rebel T2i Top Casing Replacement, Remove top casing and replace with a new casing.: 步骤 6 中的图像 1,2 Canon EOS Rebel T2i Top Casing Replacement, Remove top casing and replace with a new casing.: 步骤 6 中的图像 2,2
    • Remove the circled wires on the front with your fingers.
    • Remove the top casing and replace it with a new one. This casing should include a new power switch. Reconnect all wires and replace the back and front casings.
结论
This guide demonstrates how to replace the power button. To reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
Stefan Seitler
于10/27/14注册
470 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-4, Duarte Fall 2014 UMass Dartmouth, Team 1-4, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G4
3 名成员
创作了4篇指南
一条评论
The top cover assembly part number for the Rebel T2i/EOS 550D is CG2-2756-010.
ogminlo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 2,813
