跳转到主内容
Canon EOS Rebel T2i Hot Shoe Replacement
你所需要的
  1. Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: 步骤 1 中的图像 1,3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: 步骤 1 中的图像 2,3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: 步骤 1 中的图像 3,3
    • Using the flat end of the spudger, carefully pry the rear part of the hot shoe baseplate upward.
    • Pull the spudger backwards to remove the base plate.
    • Removing this plate reveals the mounting screws for the hot shoe.
  2. Canon EOS Rebel T2i Hot Shoe Replacement: 步骤 2 中的图像 1,1
    • To remove the hot shoe, unscrew the 4 mounting screws holding it in place.
  3. Canon EOS Rebel T2i Hot Shoe Replacement: 步骤 3 中的图像 1,1
    • With the screws removed, the hot shoe can now be lifted out of place.
结论
To reassemble your device, follow these instructions in reverse order. When tightening screws that hold the hot shoe in place, be very careful to not scratch the rail of the hot shoe. If the rail of the hot shoe has any scratches or dents, it can be more difficult to mount the external flash.
2等其他人完成本指南。
Jacob Jaskolka
于03/30/15注册
745 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-1, Shastany Spring 2015 UMass Dartmouth, Team 1-1, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S1G1
3 名成员
创作了4篇指南
一条评论
My hot shoe actually came off. I have ordered various sizes of screws to replace it but none work. I need a new hot shoe and screws. What size screws do I need with a canon rebel T2i camera?
Cindy Mitchum - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 35
总计 5,640
