跳转到主内容
Canon EOS Rebel T2i Eyepiece Replacement
你所需要的
  1. Canon EOS Rebel T2i Eyepiece Replacement, Eyepiece: 步骤 1 中的图像 1,2 Canon EOS Rebel T2i Eyepiece Replacement, Eyepiece: 步骤 1 中的图像 2,2
    • Turn off camera using the power botton on the top of the camera.
    • On the bottom of the camera, open the battery door and remove the battery.
  2. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 2 中的图像 1,1
    • Remove the 7 screws from the bottom of the camera using a Phillips screwdriver
  3. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 3 中的图像 1,1
    • On the top cover, remove the two screws from under the metal tabs that are used to attach the camera straps.
  4. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 4 中的图像 1,1
    • Remove the two screws on the right side of the camera.
  5. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 5 中的图像 1,1
    • Remove 1 screw from the left side of the camera.
    • Inside the rubber door, remove the two black screws.
  6. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 6 中的图像 1,1
    • Remove the two screw beneath the eyepiece
  7. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 7 中的图像 1,1
    • Remove the screw in the center of the viewfinder focus knob located to the right of the eyepiece.
  8. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 8 中的图像 1,1
    • Remove the two black screws on the front of the camera just above the lens mounting ring.
    • NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
  9. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 9 中的图像 1,3 Canon EOS Rebel T2i Eyepiece Replacement: 步骤 9 中的图像 2,3 Canon EOS Rebel T2i Eyepiece Replacement: 步骤 9 中的图像 3,3
    • Using the spudger and plastic opening tool, pry the back of the camera loose.
    • Remove the ribbon connector on the lower left hand side of the circuit board.
  10. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 10 中的图像 1,1
    • Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
  11. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 11 中的图像 1,1
    • Remove the ribbon connector on the upper right hand side of the circuit board.
    • Remove the microphone connection on the upper left hand side of the circuit board.
  12. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 12 中的图像 1,1
    • On the lower left side on the front of the camera, disconnect the red and yellow wires from the circuit board.
  13. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 13 中的图像 1,1
    • Pull the top cover free.
  14. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 14 中的图像 1,2 Canon EOS Rebel T2i Eyepiece Replacement: 步骤 14 中的图像 2,2
    • Remove the red wire that travels across the mirror box.
  15. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 15 中的图像 1,1
    • Remove the 4 screws holding the mirror box in place.
  16. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 16 中的图像 1,1
    • Remove 3 screws to disconnect the ribbon mount assembly
  17. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 17 中的图像 1,2 Canon EOS Rebel T2i Eyepiece Replacement: 步骤 17 中的图像 2,2
    • Now that the top assembly is free, this exposes another screw on the right side of the mirror box.
    • Remove this screw.
    • Remove the orange ribbon cable.
  18. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 18 中的图像 1,1
    • Remove the viewfinder assembly from the camera.The screws that hold the eyepiece in place are accessible. Remove these 3 screws from the rear face of the eyepiece. Two screws are located at the bottom and one screw is located on top.
  19. Canon EOS Rebel T2i Eyepiece Replacement: 步骤 19 中的图像 1,2 Canon EOS Rebel T2i Eyepiece Replacement: 步骤 19 中的图像 2,2
    • With the screws removed, the eyepiece can easily be pulled free.
结论
7等其他人完成本指南。
Jacob Jaskolka
于03/30/15注册
745 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-1, Shastany Spring 2015 UMass Dartmouth, Team 1-1, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S1G1
3 名成员
创作了4篇指南
3条评论
I used this guide to fix my 600D (Rebel T3i), and it worked like a charm.
The middle lens of my viewfinder had popped out of its plastic holder. it is now back in place, thanks to this guide.
I have added a couple of marker, to make it just that little bit easier to spot the screws and ribbon cables.
Thanks again!
dauffret - 回复
I used this guide to fix my 600D, and it also worked like a charm.
The front lens of my viewfinder (the one closest to the eyepiece) has popped out of its plastic holder.
Leo Sauermann - 回复
Thank you so much for this guide. The viewfinder lens of my 1100D came loose some days ago and this guide served perfectly.
Just a heads-up to the newbies like me: Take a lot of care with the focusing screen (the one with the focus points printed on it), I tried to clean it and ruined it. Fortunately, the replacement is not expensive, but still, better not touching it with anything.
Martin Elsner Ramos - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 4,670
