跳转到主内容
Canon EOS Rebel T1i Camera Battery Notch Replacement
你所需要的
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: 步骤 1 中的图像 1,2 Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: 步骤 1 中的图像 2,2
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a JIS #000 screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 2 中的图像 2,2
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 3 中的图像 3,3
    • Unscrew the bottom three 4mm screws with a JIS #000 screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 4 中的图像 1,1
    • Unscrew the inner 4mm screw with a JIS #000 screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 5 中的图像 1,2 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 5 中的图像 2,2
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 6 中的图像 1,3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 6 中的图像 2,3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 6 中的图像 3,3
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 7 中的图像 1,3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 7 中的图像 2,3 Canon EOS Rebel T1i Camera Battery Notch Replacement: 步骤 7 中的图像 3,3
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
结论
4等其他人完成本指南。
Jonathan Lin
于04/14/14注册
548 声望
创作了4篇指南
团队
Cal Poly, Team 3-41, Maness Spring 2014 Cal Poly, Team 3-41, Maness Spring 2014 的会员
CPSU-MANESS-S14S3G41
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 46
总计 3,372
