简介
This guide shows you how to install the anchors for the camera strap.
  1. Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Turn Camera over.
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  6. Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  7. Lay the camera on its back.
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  8. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  9. Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
    • Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
  10. Unscrew the screws that hold the remaining strap anchor.
    • Unscrew the screws that hold the remaining strap anchor.
      • Two 4.9 mm Phillips screws
结论
Kyle Reis
于2012年04月02日注册
49 信誉积分
创作了4篇指南
团队
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G9
5 名成员
创作了12篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 1,028
