本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide shows you how to install the logic board that controls the flash.
你所需要的
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Using a #00 Philllips screw driver, unscrew the 6.8 mm Phillips screw that holds the strap anchor noted by the red circle.
Remove the strap anchor.
Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
Using a 00 Phillips screw driver, unscrew the 7.4 mm Phillips screw on the top of the camera.
Using a 00 Phillips screw driver, unscrew the 4.9 mm Phillips screw on the top of the camera.
The large cylindrical object on the right side of the board is the flash capacitor.
Touching the circuit board while the capacitor still holds its charge may result in a painful electric shock that you will long remember.
To make the board safe to work on, short out the two marked terminals with a capacitor discharge tool or the blade of a screwdriver or similar implement (with an insulated handle!) You might have to use moderate pressure to punch through the white goop that covers one of the terminals.
There might be little sparks and/or an audible pop. Be careful not to short other solder connections nearby.
Unsolder all of the wires on the top of the logic board.
