跳转到主内容
Canon EOS Rebel G Lens Connector Replacement
你所需要的
  1. Canon EOS Rebel G Lens Connector Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Lens Connector Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel G Lens Connector Replacement: 步骤 2 中的图像 2,2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Lens Connector Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel G Lens Connector Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel G Lens Connector Replacement: 步骤 3 中的图像 3,3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Lens Connector Replacement, Lens Connector: 步骤 4 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the 5 indicated screws
    • Five 6.2 mm Phillips screws
  5. Canon EOS Rebel G Lens Connector Replacement: 步骤 5 中的图像 1,1
    • Using your hands, remove the top black ring.
    • WARNING! The indicated piece is spring loaded. Prepare for it to eject when taking off top ring.
    • Spring located here.
  6. Canon EOS Rebel G Lens Connector Replacement: 步骤 6 中的图像 1,2 Canon EOS Rebel G Lens Connector Replacement: 步骤 6 中的图像 2,2
    • There are two silver metal rings.
    • Remove the top silver metal ring.
  7. Canon EOS Rebel G Lens Connector Replacement: 步骤 7 中的图像 1,1
    • Remove the bottom silver ring.
结论
2等其他人完成本指南。
Zach
于04/04/12注册
43 声望
创作了8篇指南
团队
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G9
5 名成员
创作了36篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,763
