跳转到主内容
Canon EOS Rebel G LCD Screen Replacement
你所需要的
  1. Canon EOS Rebel G LCD Screen Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G LCD Screen Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel G LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G LCD Screen Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel G LCD Screen Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel G LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G LCD Screen Replacement, Top Panel: 步骤 4 中的图像 1,1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G LCD Screen Replacement: 步骤 7 中的图像 1,3 Canon EOS Rebel G LCD Screen Replacement: 步骤 7 中的图像 2,3 Canon EOS Rebel G LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 1,2 Canon EOS Rebel G LCD Screen Replacement, LCD Screen: 步骤 8 中的图像 2,2
    • Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
  9. Canon EOS Rebel G LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Lift out the LCD screen.
结论
另外一个人完成了本指南。
Zach
于04/04/12注册
46 声望
创作了8篇指南
团队
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G9
5 名成员
创作了36篇指南
一条评论
Great guide thanks! I found my lcd screen was partially working, the top part of the display was showing incomplete numbers...Cleaning the lcd contacts and reassembling it fixed the issue! No need to replace the screen in my case!
Michelangelo - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 1,556
