简介
This guide shows you how to install a new LCD screen.
你所需要的
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
另外一个人完成了本指南。
一条评论
Great guide thanks! I found my lcd screen was partially working, the top part of the display was showing incomplete numbers...Cleaning the lcd contacts and reassembling it fixed the issue! No need to replace the screen in my case!
