跳转到主内容
Canon EOS Rebel G Grip Replacement
你所需要的
  1. Canon EOS Rebel G Grip Replacement, Front Panel: 步骤 1 中的图像 1,1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Grip Replacement: 步骤 2 中的图像 1,2 Canon EOS Rebel G Grip Replacement: 步骤 2 中的图像 2,2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Grip Replacement: 步骤 3 中的图像 1,3 Canon EOS Rebel G Grip Replacement: 步骤 3 中的图像 2,3 Canon EOS Rebel G Grip Replacement: 步骤 3 中的图像 3,3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Grip Replacement, Grip: 步骤 4 中的图像 1,1
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Canon EOS Rebel G Grip Replacement: 步骤 5 中的图像 1,1
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Canon EOS Rebel G Grip Replacement: 步骤 6 中的图像 1,2 Canon EOS Rebel G Grip Replacement: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to pop the grip off and remove grip.
结论
另外一个人完成了本指南。
Kyle Reis
于04/02/12注册
52 声望
创作了4篇指南
团队
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 的会员
CPSU-FORTE-S12S14G9
5 名成员
创作了36篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,567
