简介
This guide will instruct you how to remove the back panel of your camera.
你所需要的
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Using a #00 Philllips screw driver, unscrew the 6.8 mm Phillips screw that holds the strap anchor noted by the red circle.
Remove the strap anchor.
即将完成!
结论
