跳转到主内容
Canon EOS Digital Rebel (300D) Front Casing Replacement
你所需要的
  1. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the front screws: 步骤 1 中的图像 1,1
    • Remove the two 7mm philips screws from the front casing.
  2. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove bottom screws: 步骤 2 中的图像 1,1
    • Remove the three 1/8" philips screws from the bottom.
    • Remove the single 3/16" philips screw from the bottom.
  3. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the right side screws: 步骤 3 中的图像 1,1
    • Remove the two 1/8" philip screws from the right side of the front casing.
  4. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: 步骤 4 中的图像 1,2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: 步骤 4 中的图像 2,2
    • Locate the lock of the battery door and pull it for allowing the door to be removed.
    • Remove the battery door.
  5. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the battery door hinge mount: 步骤 5 中的图像 1,1
    • Remove the two 1/8" philips screws from the hinge mount.
    • Take out the door hinge mount.
  6. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: 步骤 6 中的图像 1,2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: 步骤 6 中的图像 2,2
    • Remove the screw holding the black cap which covers access holes to the screws holding the front casing to the battery compartment.
    • Remove the black cap pulling it to the right.
    • Remove the two 3/16" philips screws.
结论
Claudio Felix
于01/01/16注册
863 声望
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 1,068
