跳转到主内容
Canon EOS A2 Top Cover Replacement
你所需要的
  1. Canon EOS A2 Top Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
  2. Canon EOS A2 Top Cover Replacement: 步骤 2 中的图像 1,1
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
  3. Canon EOS A2 Top Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from inside the battery housing and set the cover aside.
  4. Canon EOS A2 Top Cover Replacement, Front Cover: 步骤 4 中的图像 1,1
    • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
  5. Canon EOS A2 Top Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the 6.4mm screw from the inside of the flash bezel.
    • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
  6. Canon EOS A2 Top Cover Replacement: 步骤 6 中的图像 1,1
    • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
  7. Canon EOS A2 Top Cover Replacement: 步骤 7 中的图像 1,1
    • Remove the 5.6mm screws behind the battery cover.
  8. Canon EOS A2 Top Cover Replacement: 步骤 8 中的图像 1,1
    • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
  9. Canon EOS A2 Top Cover Replacement: 步骤 9 中的图像 1,1
    • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
  10. Canon EOS A2 Top Cover Replacement: 步骤 10 中的图像 1,2 Canon EOS A2 Top Cover Replacement: 步骤 10 中的图像 2,2
    • Starting at the flash, carefully pull the front cover away from the camera.
  11. Canon EOS A2 Top Cover Replacement, Top Cover: 步骤 11 中的图像 1,1
    • Remove the 4.3mm screw below the camera strap ring.
  12. Canon EOS A2 Top Cover Replacement: 步骤 12 中的图像 1,1
    • Remove two 4.8mm screws located on both sides of the eyepiece.
  13. Canon EOS A2 Top Cover Replacement: 步骤 13 中的图像 1,1
    • Pull the top cover up slowly.
    • A ribbon cable is attached to the bottom of the top cover and the camera. Pull up very carefully to avoid damaging this.
  14. Canon EOS A2 Top Cover Replacement: 步骤 14 中的图像 1,1
    • Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
    • If you pull the white tabs all the way out, just insert them back in to avoid losing them.
结论
另外一个人完成了本指南。
Mark
于04/20/11注册
192 声望
创作了5篇指南
团队
Cal Poly, Team 8-9, Regan Spring 2011 Cal Poly, Team 8-9, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G9
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 4,085
