本指南有最近更改,您可查看未经巡查的最新版本。
简介
The control dial on the canon EOS A2 lies underneath the top cover of the device. The front cover must also be removed in order to access this.
你所需要的
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
Remove the 3mm screw from the back of the control dial while holding the front of the control dial.
7等其他人完成本指南。
9条评论
Is it safe to do this procedure while a film is inside the camera?
I was wondering if anyone could help me were I could possibly get the new parts?
I've looked around but found nothing relevant so far.
Thanks in advance,
Agoston Horanyi
Did you find the parts ? If no go to eBay.
as exemple : https://www.ebay.com/itm/Canon-EOS-A2E-R...
gilberto -
