跳转到主内容
Canon EOS 6D Analog Screen Replacement
你所需要的
  1. Canon EOS 6D Analog Screen Replacement, Rear Body Panel: 步骤 1 中的图像 1,1
    • Remove the viewfinder cover by pinching the sides and sliding it upward.
  2. Canon EOS 6D Analog Screen Replacement: 步骤 2 中的图像 1,1
    • Open the battery door on the bottom of the camera.
    • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
  3. Canon EOS 6D Analog Screen Replacement: 步骤 3 中的图像 1,1
    • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
  4. Canon EOS 6D Analog Screen Replacement: 步骤 4 中的图像 1,1
    • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
    • Rotate the covers to the side so that you can see the connection ports inside.
    • Remove the following screws:
    • Two silver 5mm Phillips #00
    • One black 6mm Phillips #00
  5. Canon EOS 6D Analog Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
  6. Canon EOS 6D Analog Screen Replacement: 步骤 6 中的图像 1,1
    • Rotate your camera so the bottom side is facing you.
    • One 6mm Phillips #00
    • Two 3mm Phillips #00
  7. Canon EOS 6D Analog Screen Replacement: 步骤 7 中的图像 1,1
    • Rotate your camera so the back is facing you.
    • Three silver 5mm Phillips #00
    • Two black 6mm Phillips #00
    • One black 4mm Phillips #00
  8. Canon EOS 6D Analog Screen Replacement: 步骤 8 中的图像 1,2 Canon EOS 6D Analog Screen Replacement: 步骤 8 中的图像 2,2
    • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
    • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
    • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
  9. Canon EOS 6D Analog Screen Replacement, Front and Top Body Panels: 步骤 9 中的图像 1,1
    • Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
  10. Canon EOS 6D Analog Screen Replacement: 步骤 10 中的图像 1,1
    • Rotate the camera so the side with the SD card slot is facing you.
    • Remove the 4mm Phillips #00 screw from the bottom edge of this side.
  11. Canon EOS 6D Analog Screen Replacement: 步骤 11 中的图像 1,1
    • Rotate the camera so the bottom is facing you.
    • Two 8mm Phillips #00
    • One 4mm Phillips #00
  12. Canon EOS 6D Analog Screen Replacement: 步骤 12 中的图像 1,1
    • Remove the bottom panel from the camera by using your fingers to pull outward on the tab inside the battery compartment.
  13. Canon EOS 6D Analog Screen Replacement: 步骤 13 中的图像 1,1
    • Rotate the camera so the front is facing you.
    • Three 5mm Phillips #00
    • Two 6mm Phillips #00
  14. Canon EOS 6D Analog Screen Replacement: 步骤 14 中的图像 1,1
    • One 4mm fine-thread Phillips #00
    • Two 4mm coarse-thread Phillips #00
  15. Canon EOS 6D Analog Screen Replacement: 步骤 15 中的图像 1,1
    • The red speaker wire is attached to the inside of the front panel. Opening the front panel forcefully may break it.
    • Slowly fold the front panel to the right without pulling it away from the right edge of the camera.
  16. Canon EOS 6D Analog Screen Replacement: 步骤 16 中的图像 1,1
    • Remove the 4mm Phillips #00 screw on the inside of the front panel to separate the panel from the speaker wire.
  17. Canon EOS 6D Analog Screen Replacement: 步骤 17 中的图像 1,1
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the strap hook.
  18. Canon EOS 6D Analog Screen Replacement: 步骤 18 中的图像 1,1
    • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the shutter button.
  19. Canon EOS 6D Analog Screen Replacement: 步骤 19 中的图像 1,1
    • Rotate the camera so the top is facing you.
    • Remove the 6mm Phillips #00 screw from next to the analog screen.
  20. Canon EOS 6D Analog Screen Replacement: 步骤 20 中的图像 1,1
    • Rotate the camera so the back is facing you.
    • Remove the Phillips #00 screw from the viewfinder focus.
  21. Canon EOS 6D Analog Screen Replacement: 步骤 21 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully detach the two light brown ribbon wires on the top panel:
    • The right ribbon by prying it out with the flat end of the spudger.
    • The left ribbon by using tweezers to gently wiggle it out toward the top.
  22. Canon EOS 6D Analog Screen Replacement: 步骤 22 中的图像 1,1
    • A ribbon wire connects the inside of the top panel to the body of the camera.
    • Slowly lift the top panel to about an inch above the body of the camera.
    • Carefully use the flat end of the spudger to detach the ribbon wire from the top of the camera.
  23. Canon EOS 6D Analog Screen Replacement: 步骤 23 中的图像 1,1
    • Grip the remaining side panel with your fingers and gently pop it off the camera.
  24. Canon EOS 6D Analog Screen Replacement, Analog Screen: 步骤 24 中的图像 1,1
    • Use the pointed end of the spudger to flip up two silver ribbon wire latches on the inside of the top panel.
  25. Canon EOS 6D Analog Screen Replacement: 步骤 25 中的图像 1,1
    • Use the pointed end of the spudger to slide out the two light brown ribbon wires.
  26. Canon EOS 6D Analog Screen Replacement: 步骤 26 中的图像 1,1
    • Use the pointed end of the spudger to carefully remove the third light brown ribbon wire.
  27. Canon EOS 6D Analog Screen Replacement: 步骤 27 中的图像 1,1
    • Remove four 5mm Phillips #00 screws from the inside of the top panel.
  28. Canon EOS 6D Analog Screen Replacement: 步骤 28 中的图像 1,2 Canon EOS 6D Analog Screen Replacement: 步骤 28 中的图像 2,2
    • Carefully slide the flat end of the spudger underneath the screen and lift it out.
结论
9等其他人完成本指南。
Justin Thomas
于04/22/14注册
2,188 声望
创作了6篇指南
团队
Cal Poly, Team 11-48, Amido Spring 2014 Cal Poly, Team 11-48, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G48
4 名成员
创作了18篇指南
2指南评论
any way to replace the sd card side panel without having to take the lcd panel off
Nate Kennedy - 回复
Thank you Justin! Very well done. Fixed the camera for $40 rather than replacing it for 1000+
Matt Ryan - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 16
过去 30 天: 66
总计 7,725
